2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-17T20:03:20+00:00
    @TimBarley stay tuned. We think we got this one but need a little more time to confirm through depth testing. — Brian Hall (@IsForAt) August 16, 2016
    A little bit of good news worth sharing although why that information can't be shared here is beyond me.  Then again why should I expect the leopard to change it's spots now.
    Also something that suddenly occurred to me today, isn't it true that you can't take an electronic device on a plane unless they can turn it on at security (this might be UK airports only)?  That means it isn't even possible to take an SP3 on a plane with the intention of using it plugged in at your destination.  Just another example of the fiasco that this situation has become.
    Who is this Tim Barley guy and why does he get such a quick response from Brian Hall?  Are they old drinking buddies or something?  Meanwhile, there's 84 pages of people asking nicely for answers about what was billed as premium hardware that are being completely ignored.
    Here I thought this was the place you are supposed to go to ask Microsoft employees for support questions, but apparently you have to be the right person on Twitter to get any kind of answer at all.
    At this point, even if Microsoft does make this right, I'll be really hesitant to buy any more hardware from them.
    2016-08-17T20:09:20+00:00
    Just like to put in my 0.02.
    Class action lawsuit may be the only option at this time BUT people have to realize what usually happens with these lawsuits.
    Typically, class action lawsuits only return small fraction of damage to the people after the lawyers take their cut. So to make an assumption, each person with battery issue may end up with $50, $100, or something like that.
    All I'm trying to say is that the class action lawsuit is not the ideal solution here. Instead, Microsoft should offer a solution be it software fix or hardware replacement.
    Good luck to all.
    2016-08-17T20:21:07+00:00
    Good luck to all.
    A class action lawsuit would not only settle on the cost of the device, but the cost the failure may have incurred on the claimants. This would include loss of revenue, productivity, man hours dealing with the issue and the distress caused by the device failure, along with the total number of devices sold.
    This could add up to quite a hefty amount per device and considering class action lawsuit amounts cover all the potential victims, those who share the compensation would only be those who registered by a given amount of time, but would get an equal share of the grand total, less fees.
    It could amount to a great deal more per person than the cost of the device.
    Lawyers retire on fees from class action lawsuits against large corporations.
    2016-08-17T20:54:55+00:00
    So, I received my replacement surface today, as I contacted MS during my year warranty.
    Funny how those in warranty seem to be treated completely differently.
    Well, I received it and decided to have a look at the battery. Design capacity 42k, actual capacity, 40k. Cycles, 417.
    The display driver crashes constantly, every time I press start to be precise, every app I open crashes too.
    Things are off to a good start.
