2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-17T19:09:26+00:00
    Just got back from the Microsoft Store in Christiana, DE to see what they could do with my completely dead SP3 with SIMPLO battery that had been operating with charger at 144 mWh battery until it failed to boot a week ago. A two hour ride for nothing. The store was pretty much empty so I was waited on immediately. The Microsoft tech at the store actually told me that the tablets and laptops were only designed to last two years and if I had gotten the extended warranty I would have been ok. To add insult to injury he also stated that because I was a Microsoft Preview Insider, that if I had read the small print, I would know that it automatically invalidated my warranty if I had a warranty. The only thing that he was  authorized to offer me was another out of warranty unit for $450.00. I turned it down. The interesting thing that I noticed in the Microsoft store was that most of the tablets and computers in the store were DELL. Maybe the Microsoft store realizes that the handwriting is on the wall for Microsoft hardware products.
    2016-08-17T19:18:38+00:00
    This is very good news indeed. I wonder if this mean a fix will bring our batteries back to a higher capacity or just stop the degradation.
    For many of us, without the former, the latter is irrelevant.
    2016-08-17T19:46:33+00:00
    Just adding my name to the dissatisfaction with my SP3.  Love love loved it when I got and it was the perfect tool for a freelance writer.
    Now, a charge doesn't last more than about 20 minutes with the percentage counter going all over the place until it shuts itself down (even if it still has "time" left).
    I can't afford to replace it and it's quite frustrating that my "mobile" option is the clunky laptop I was trying retire.
    I keep watching the news for a class action suit because it's got to be coming...
    2016-08-17T19:57:23+00:00
    Already here. Lawyers waste no time when they smell blood.
    http://www.classlawdc.com/2016/07/26/migliaccio-rathod-llp-investigates-microsoft-surface-pro-3-battery-failures/
