2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-17T17:47:09+00:00
    I just purchased a Dell. This thing is practically unusable.
    2016-08-17T17:48:14+00:00
    if you plug it in, no peripherals attached, NOT docked, can you boot and use it
    or not?
    >>I'm fully bricked now
    2016-08-17T18:00:36+00:00
    Update on my SP3:
    • About 2 weeks ago my battery would drain in about 20-30 minutes, tops. Battery report showed 8,000mWh.
    • Last night I tried unplugging it to see what would happen. I watched the battery state on the tray icon go 100-95-85-80-70 and then shut down hard in about 6 seconds flat! Battery report now shows 1400mWh.
    It still works while plugged in for now, so I made sure to do a backup last night to an external drive.
    Luckily for me, I bought a 3rd party extended warranty through SquareTrade which is still in effect. But I will hold out a little longer as that would likely get me a refurb unit with a new battery, which may or may not get the issue again, and I will have $450 less value on my extended warranty. Hopefully MS can get their S&%T together and communicate something to us!
    Also would like to give a shout out to SquareTrade warranties. I have bought a few in the past on various devices and have filed claims with them a few times with great results every time, no haggling. It's usually longer and better covered than the factory extended warranties, while being a little cheaper as well. If I end up using it this time around as well I will report back how they handle it.
    2016-08-17T18:03:27+00:00
    I will personally committing time to write bad reviews on as many sites as I can. We must make the surface brand synonymous with bad batteries and poor customer service. It will remain that way for me at least until microsoft can get my $2000 brick working again.
