2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-17T14:07:09+00:00
    "stop the degradation" would sound like cheap or no fix at all... Our battery back to a decent capacity corresponding to a normal degradation (from the actual sad 144 to around at least 38000 mWh for my case) would be a real fix.
    2016-08-17T15:34:32+00:00
    I'm fully bricked now and have shifted to a backup laptop.  This is madness.  In a last ditch effort, I thought I'd try to get some satisfaction from the Microsoft Store.  Unfortunately, there's not one where I live.  As I will be near one for a soccer tourney on Sunday, I thought I'd call and see what my chances are at getting a replacement without paying the $450 fee.  The Microsoft Store technician I spoke with in Overland Park KS indicated Microsoft is not offering out of warranty replacement on SP3s with the battery problem.  I'm still waiting on a fix, processing a credit card extended warranty claim, and joining the class action (which I never thought I'd do).  Way to go Microsoft. . . .
    2016-08-17T16:09:13+00:00
    Does anyone have the original copy of the manufacturers warranty that was included with your SP3?  I can find one online, but I'm not sure if it has changed since I bought it in December, 2014.
    2016-08-17T16:42:01+00:00
    unfortunately, u haven't even experienced the horrible battery life to come.  these batteries die in two years.  simply quit charging.  and no way to repair or replace.  should be a class action suite soon.  just horrible.  it will happen to you-
