2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-16T13:28:51+00:00
    HelloKridsada Thanabulpong,
    Thank you for reaching out to the Surface community. Sorry to hear you are having issues with your battery. If you do in fact have a hardware issue it would be a Warranty/Service related issue that you would have to contact Assisted Support to resolve if you do not have a Microsoft Store in your country. However, to try to determine what is going on with your Surface's battery please follow the troubleshooting steps in this link.
    Please reply with what steps you've tried and what the results were.
    Best Regards
    I have tried, and I think most of the people complaining of this issue have also tried the troubleshooting steps. The "trouble" is with the Microsoft product. We want our batteries replaced at no costs! It's ridiculous and unheard of for a battery to go out on a device 12-18 months from the date of purchase. MS should be ashamed and embarrassed, as opposed to encouraging us to pay $99 for customer service that will tell us to mail our Surface's in so we can buy a battery from you!
    SORRY... with all due respect this is NOT answering the important question here.
    My Battery has been slowly degrading for weeks now, and now can only hold 10% of the original capacity after a full charge. By the time I leave home and travel 15 minutes to work, it's down below 40%. My Surface Pro 3 is only 18 months old, yet when I run the battery report, I see this accelerated degradation started almost a year ago. The reason I didn't notice it was because I dock it almost every day at work. I only travel once or twice a month... but when I do it's critical it has at least 4 to 5 hours of power.
    So the question is NOT how to fix this, BUT WHY ARE THESE BATTERIES SO BAD? Why are they failing prematurely, and more importantly what is Microsoft doing about it?
    Sad part is I my Surface is useless if you can't take it on the road.
    2016-07-16T14:57:53+00:00
    Bob, run a battery report (admin cmd prompt, then powercfg /batteryreport) and then upload the results, including the manufacturer of your battery.
    2016-07-16T15:30:25+00:00
    2016-07-17T01:15:07+00:00
    The slide down is in progress here.
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1181359620
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 21,523 mWh
    CYCLE COUNT 311
    Battery capacity history
    Charge capacity history of the system's batteries
    2015-11-22 41,541 mWh 42,157 mWh
    2015-11-22 - 2015-11-29 41,385 mWh 42,157 mWh
    2015-11-29 - 2015-12-06 41,130 mWh 42,157 mWh
    2015-12-06 - 2015-12-13 41,087 mWh 42,157 mWh
    2015-12-13 - 2015-12-20 40,728 mWh 42,157 mWh
    2015-12-20 - 2015-12-27 40,654 mWh 42,157 mWh
    2015-12-27 - 2016-01-03 40,604 mWh 42,157 mWh
    2016-01-03 - 2016-01-10 40,543 mWh 42,157 mWh
    2016-01-10 - 2016-01-17 40,579 mWh 42,157 mWh
    2016-01-17 - 2016-01-24 40,774 mWh 42,157 mWh
    2016-01-24 - 2016-01-31 40,785 mWh 42,157 mWh
    2016-01-31 - 2016-02-07 40,789 mWh 42,157 mWh
    2016-02-07 - 2016-02-14 40,896 mWh 42,157 mWh
    2016-02-14 - 2016-02-21 41,012 mWh 42,157 mWh
    2016-02-21 - 2016-02-28 40,916 mWh 42,157 mWh
    2016-02-28 - 2016-03-06 40,810 mWh 42,157 mWh
    2016-03-06 - 2016-03-13 40,720 mWh 42,157 mWh
    2016-03-13 - 2016-03-20 40,725 mWh 42,157 mWh
    2016-03-20 - 2016-03-27 40,898 mWh 42,157 mWh
    2016-03-27 - 2016-04-03 40,838 mWh 42,157 mWh
    2016-04-03 - 2016-04-10 40,935 mWh 42,157 mWh
    2016-04-10 - 2016-04-17 40,647 mWh 42,157 mWh
    2016-04-17 - 2016-04-24 41,883 mWh 42,157 mWh
    2016-04-24 - 2016-05-01 41,258 mWh 42,157 mWh
    2016-05-01 - 2016-05-08 42,579 mWh 42,157 mWh
    2016-05-08 - 2016-05-15 41,929 mWh 42,157 mWh
    2016-05-15 - 2016-05-22 41,677 mWh 42,157 mWh
    2016-05-22 - 2016-05-29 42,583 mWh 42,157 mWh
    2016-05-29 - 2016-06-05 42,583 mWh 42,157 mWh
    2016-06-05 - 2016-06-12 42,503 mWh 42,157 mWh
    2016-06-12 - 2016-06-19 39,724 mWh 42,157 mWh
    2016-06-19 - 2016-06-26 35,256 mWh 42,157 mWh
    2016-06-26 - 2016-07-03 30,672 mWh 42,157 mWh
    2016-07-04 27,413 mWh 42,157 mWh
    2016-07-05 27,181 mWh 42,157 mWh
    2016-07-06 26,503 mWh 42,157 mWh
    2016-07-07 26,038 mWh 42,157 mWh
    2016-07-08 25,283 mWh 42,157 mWh
    2016-07-09 24,407 mWh 42,157 mWh
    2016-07-10 23,896 mWh 42,157 mWh
    2016-07-11 23,639 mWh 42,157 mWh
    2016-07-12 23,216 mWh 42,157 mWh
    2016-07-13 22,698 mWh 42,157 mWh
    2016-07-14 22,108 mWh 42,157 mWh
    2016-07-15 21,839 mWh 42,157 mWh
