2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-17T10:13:54+00:00
    Symptoms:
    A: On Boot a 1cm square appears near the top right hand corner. Swiping up across it removes it.
    B: Reported Battery capacity drops every day. (PowerCFG)
    C: Battery life estimates are now at 4 hours (PowerCFG) but usage 2-3 hours; when until recently I had 7 - 9 hours consistent real world usage
    D: Taskbar battery life estimates are erratic, fluctuating wildly.
    E: Touch screen is intermittently responsive. I have a 'gut feel' there is a pattern but can't confirm a repeatable one. eg Detaching the keyboard has 50% consistent problem to screen touch.
    F: Device heats up while type cover is closed (Standby activity - despite OS settings)
    System State
    • Clean install of Windows 10 Anniversary Edition
    • Subsequent updates all applied successfully
    • Software installed MS Office Suite, Visio and Project. Adobe Lightroom and Photoshop
    • Onedrive sync paused
    • Background apps disabled
    • Startup apps disabled
    • MS Scheduler all at default (ie not touched)
    • Screen touch calibrated, but not pen calibrated (need batteries replaced)
    Usage
    • Surface only charged after the battery is drained and then only while being used.
    • Once a full charge is reached and I'm not using the device, the surface is shut down (not standby) and disconnected from power - A few posts reported this as a fix, sadly it isn't for this device.
    Observations
    • Symptoms appeared together 3-4 months ago. At the time I thought it was a 'tired' OS that needed a clean install, so I waited for the Anniversary Edition of Windows 10 to be released to do this.
    • While I have seen all these symptoms reported in the same time frame, I haven't seen any posts that describe them concurrently.
    • I don't believe this is a hardware issue as the issues appear intermittent but have regular patterns to them, (no I can't describe them in a repeatable way)
    Request
    • Microsoft, you have noted that there is a battery problem, but can you link these other symptoms?
    • Microsoft, can you put a timeline on a published fix?
    Personal Comments
    • Please, Microsoft fix this. My SP3 is my daily driver at work and home.
    2016-08-17T10:57:11+00:00
    You know, that's a great point. Bad publicity may be our next strategy since we're getting nowhere here by asking nicely. Microsoft can keep ignoring us and pretending that this isn't a major issue because we're trying to get them to acknowledge this on their terms in the random corners of the Internet where nobody is paying attention. It seems to me that nothing get attention faster than bad press. Why don't a few of us get in touch with our local cable news network and try to get some airtime on the topic. ...
    I think if people put their reviews, experiences and other comments on AMAZON's Surface Pro 3 review page they will have more impact than limiting them to Microsoft's site.  You don't have to have purchased your device there to review it there.
    2016-08-17T13:49:04+00:00
    I have a SP3, bought in Feb 2015. Over the past 12 days the same symptoms have been seen, with battery capacity dropping by ~1000mWh a day. Currently around 30,000, but based on what I've read here, it will keep dropping till it is unusable.
    Based on this I called MS Support (UK) - the device was bought directly from the MS online store.
    The engineer I spoke to acknowlegded that it is an known issue and asked me to provided proof of purchase and an up to date battery support. He advsied that they were 'hopeful' that a fix (ie: windows/firmware update) woudl be available soon. I pressed him as on the fact that I have a device which, based on others experiences will be useless in about 3 weeks time. he then spoke to a supervisor and advsied that if there was no fix next week, they woudl look to replace my device (no detail on what for - I assume reconditioned but the same spec??).
    I will have to wait and see if that actually happens, but he didn't seem to push back too much.
    BTW - my warranty expired at the end of May, but he said that they would make an exception as it was 'a known issue'......very interesting to hear that based on the mixed expeirences others have had here wiht MS Support on this matter.
    2016-08-17T13:55:19+00:00
    This is very good news indeed. I wonder if this mean a fix will bring our batteries back to a higher capacity or just stop the degradation.
