2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-15T22:55:49+00:00
    Chiming in.
    Name X898289
    Manufacturer SIMPLO
    Serial number 1161370116
    2016-07-16T04:23:55+00:00
    I received an email asking me if my problem was resolved and if not to reply to this post. My issue has NOT been resolved. Microsoft owes me and many others new batteries!
    2016-07-16T10:14:14+00:00
    open an administrative cmd prompt and run
    what manufacturer is your battery?
    Barb
    MVP-Windows and Devices for IT
    2016-07-16T13:05:25+00:00
    I'd like to see the HISTORY so I can see the drops.
