2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-15T14:12:40+00:00
    I start to notice this problem when i try to unplug my SP3 from the AC plug for a movie. It's gone to dead IMMEDIATELY.
    Thanks to this forum, I then start to generate my own battery report. It seem the battery start to die out in April 2016.
    It doesn't seem to be isolated case for many of us here.
    I purchased this SP3 in Nov 2014, with extended warranty. Hopefully the shop will bare the replacement cause if not Microsoft.
    2016-08-15T14:48:51+00:00
    Just bought surface pro 3 on July 2015. Almost a year ago. Now my battery suck. People should stop buying surfaces. Invest 500+ dollars to lose it in 1 year? No thanks.
    2016-08-15T15:14:10+00:00
    Would Arnulfo Avi please comment on why Greg's comment was marked as an answer when it doesn't a) offer any actions to take to reduce damage, or prolong device life. b) any time frame for remediation of affected units?
    Further to this, if the solution is truly able to be resolved via software update, this still poses a problem for many people where who are subject to issues where by the devices do not remain powered on even while connected to mains power with the original power-brick (not a surface dock), or the devices do not complete boot at all?
    Further again, can someone at Microsoft commit to notifying your official support tracts to this issue? Continued reports of experiences with Microsoft Store employees and Phone support workers being ignorant to the issue is troubling.
    PS: My own experience with the phone support occurred when I tried calling the local Microsoft Store. I was routed to the general Microsoft Support line. Conversation here degraded with me asking to talk to someone, anyone who could actually talk about this issue without requiring a $99 fee paid. Eventually the tech routed my call to a line which repeated "Please wait" or similar until eventually disconnecting.  I presume this is a method of getting off the call gracefully when the caller is insistent on talking with someone who isn't "on-script."
    2016-08-15T16:20:45+00:00
    I have the same problem.  I am unable to unplug the Windows Surface Pro 3 without it immediately shutting down.
    Windows Surface is a mobile device.  If I can't move around with it, it is worthless to me.
    Fix it or provide me a replacement for defective hardware or software.
    Suffice it to say this will be the last time I purchase Microsoft hardware if a speedy resolution isn't provided.  You won't lose just me as a consumer, but an IT leader that influences large purchases.
    Rich Thompson
