2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-15T12:57:54+00:00
    Hello Greg,
    can you please respond, or if you have been gagged by your management, escalate the issue so someone responds with an update?
    I have 4 Surface Pros (Pro 1, Pro 2, 2x Pro 3) - the Pro 1 & Pro2 still maintain their charge despite being quite old now. Both Pro 3s have the same issue and now can only be used when connected to the charger.
    I just got of chat with Microsoft Support and they "acknowledge" that there is an issue with the batteries, and offered me replacement units at a cost of £333.33 each (I am in the UK). However they could not confirm if the replacements units would not have the same issue, and actually said there is a likelihood of them having the same issue and best to wait for a fix. They have received several of my battery reports confirming the degradation over the last few weeks as evidence.
    Now I am a supporter of Microsoft and love the Surface, and would rather wait for a fix, but you (or your management) really need to get ahead of this and give some indication of a fix. It will put the community's fears to rest if you do. The silence, as you can see from these posts, means people who reply on their Surface are now very worried they have invested in the wrong item.
    As I said a fix is preferred, if that is even technically possible.
    We all look forward to your reply.
    N.
    2016-08-15T13:13:36+00:00
    Hi Greg,
    I can not detach from the powerplug in the wall and when executing CPU hungry applications, it just shuts down the SP3.
    Examples are Bing Maps or Google Maps. Lowering the screen intensity, I was able to use these sites.  And my sight is not that good to view information at 25% brightness.
    One thing is: Microsoft is aware and the other is: estimated timeframe towards a solution.
    Just because I am part of a limited number of customers, does this problem get the needed attention to be solved promptly?
    Thank you.
    2016-08-15T13:13:41+00:00
    I'm in the same situation; where previously I was in a position to use the surface only on AC power and wait for Microsoft to issue a fix or a recall, it's now at the critical stage where my Surface sometimes won't even stay on while in the AC dock. I suspect at this rate of decline, it will be unusable within a week. This means
    -not being able to download and update if MS do release a fix (a possibility that is looking ever more unlikely)
    -not being able to work, as this is my work computer. The process of buying a new laptop, installing all the various software, and therefore accepting the financial liability for MS's inability to fix the problem, is huge.
    Please would it be possible for MS to issue some kind of response to the situation beyond 'we think we might know maybe, we're looking at a fix sort of'. For affected users, the problem has become critical, and we need to know some sort of timescale over which this may be solved.
    2016-08-15T14:03:08+00:00
    Hello Greg,
    Greg now loads grocery carts at the end of the register conveyor belt. He tried to provide some customer service and help those who are suffering from this device defect, which is not company policy. Instead of waiting for the lawyers to determine whether attempting to fix or just paying damages from a lawsuit would be cheaper, he offered the potential for a fix, which the marketing team considered detrimental to their $450 refurb purchase program, boosted by this defect.
    As a correction to this, Microsoft has deployed the marketing team to encourage "Microsoft MVPs" and "Windows Insider" subscribers to hit the forums with pro Microsoft responses to play down the issues and undo Greg's mistake.
