2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-15T03:56:43+00:00
    Nothing suspicious about the 8/1 update.  You now have the 1607 release which starts all event logs over again.  Look in windows.old and it will be in there.
    Bottom line this isn't Microsoft trying to hide the issue.
    2016-08-15T06:27:53+00:00
    You know, telling us that a release resets all the logs, does not imply there's nothing suspicious. It implies there was something Microsoft wanted removed. Why should any software release require existing data to be deleted?
    The bottom line is, one of the following is true: -
        a) Microsoft IS trying to remove evidence of something.
        b) Microsoft IS being negligent, erasing data that might be quite important, from users devices.
    2016-08-15T09:05:29+00:00
    Dear K. Krisada,
    I also have the same problem with you.
    My Surface pro 3 have Simplo battery which just significantly lose charges after month of July.
    Already contact the Microsoft support from Thailand, asked to pay about Bath 20,000- for complete exchange of the Surface Pro 3 Unit. (Which is more expensive than in the US.)
    Actually my current Surface Pro 3 is the replacement unit of the original unit I purchased more than a year ago.
    I'm really hope that Microsoft will find someway to fix the problem really soon since my Surface Pro 3 already loss charge about 50 % already.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=fc679b99-9a95-4b0e-a30c-2543b25bebcb)![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=76a357c8-5751-4973-8f86-18ed3a1e8f00)
    2016-08-15T11:20:40+00:00
    I think it's important to understand the distinction between a normal Windows Update and a Windows 10 Feature Update (The 1607 / Anniversary Update is the latter).  In the Windows 10 era a Feature Update is a full build of Windows, like installing an upgrade from Windows 7 to Windows 8 for example), and causes your Windows folder to be renamed Windows.old and then a new Windows folder is created from decompressing the new WIM (Windows Image) file before finally merging your settings, etc.  That is why your old history has been moved.
    This is why, since the Windows Vista/7 era, it is no longer necessary to do a "clean" install since essentially every Windows upgrade is now a new installation but with your personal files and folders (and most customisation) is retained and merged back into the new installation so it appears like an upgrade.
    While it is easy to roll out the tin foil conspiracy theories there is a rational explanation for your experience.  Steven Sinofsky did a blog post on this new upgrade experience in the Building Windows 7 blog which is still discoverable today.  People like to hate on Vista but actually while the OS was troubled it was the beginning of many technologies that makes Windows 10 as secure and componentised as it is today.
    End of history lesson. :)
    EDIT: Found the link which is actually about Windows 8 but explains how Windows 7 copied retained files back into the new installation which is different to how Windows XP and before did upgrades: https://blogs.msdn.microsoft.com/b8/2011/11/21/improving-the-setup-experience/
