2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-14T22:45:19+00:00
    Why has this been marked as the answer?
    2016-08-14T23:01:07+00:00
    It's not an answer. What they mean is; it's the only answer we'll get and it's an acknowledgement at best, not an answer!
    2016-08-15T00:58:17+00:00
    Hi Greg,
    has a solution been found, experiencing same issue with powercfg /batteryreport /output %USERPROFILE%\Desktop\battery_report.html showing my battery down to 2,941 mWh.
    I just updated firmware and doesn't look like it changed anything.
    thx
    Sev
    2016-08-15T03:07:53+00:00
    Ditto. Started in March for me.
    And
    Also the 8/1 update deleted my battery history which is super suspicious. Basically it eliminates any evidence that degradation started before warranty was up. Glad I kept the report.
    But the 8/1 update did nothing to fix this.
    Desperately waiting on this fix. Following this thread.
    Phil
