2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-14T04:20:02+00:00
    I powered down my Surface 3 last night. The following afternoon, the battery was dead. Not sure how this happened.
    2016-08-14T04:26:56+00:00
    Hi there,
    I am one of them, and the AC adapter is even sometimes not enough as well, probably because I need to plug a mouse / keyboard through a usb hub on the unique usb port hereby left. I confirm that there is no way to boot windows 10 while my SP3 I7-256 is plugged on the dock, and that it even crashes now more rarely while on AC adapter.
    I have started my backups... I am not happy at all because I fear it would crash in the middle. It is a very uncomfortable situation.
    To this forum, my battery is a Simplo... Is there any real hope for a software fix on this ?
    People are saying that the 1st August update did not solve the issue neither. With all the respect, your frankness would be appreciated because after the still unresolved overheating problem, this last one is a quite epic cherry on the cake.
    Thanks.
    2016-08-14T04:43:23+00:00
    Mine has never been used in conjunction with a docking station. I've never even seen one.
    2016-08-14T13:43:32+00:00
    I use the docking station with my SP3 most of the time. Shame we can't create a survey in this topic to find the ratio of docking station users with this problem.
    I don't have a docking station and have always used the SP3 on the mains adapter. My SIMPLO batteries now show c7Wh.
