2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-13T23:54:44+00:00
    I deleted and re-installed the acpi driver as part of my earlier troubleshooting - we have the same version - still have same problem unfortunately.  I was hoping to pull back the bios update back to before the January update.  In January it looks like the first update where MS published 'better' battery drivers that my system currently has (from update site: "Microsoft Surface ACPI-Compliant Control Method Battery driver update (v1.2.0.2) ensures correct surface driver is installed").  I hope your battery doesn't keep falling.
    2016-08-14T01:51:18+00:00
    I also have the issue.  I use my surface pro 3 connected to a docking station most of the time.
    The use of a docking station seems to be mentioned quite frequently in this topic which has me wondering if that is possibly part of the problem; not the docking station itself but the discrepancy between the power it supplies and what the Surface Pro 3 draws under load. Perhaps that has confused the charging state of the battery, in software, or perhaps resulted in the early demise of the physical batteries.
    I use the docking station with my SP3 most of the time. Shame we can't create a survey in this topic to find the ratio of docking station users with this problem.
    I too use the docking station most of the time. Back when this happened to my Surface and it was otherwise not reported, I assumed this was a side effect of being plugged in for a long period of time. Not that it makes it acceptable.
    2016-08-14T03:27:14+00:00
    Greg,
    While engineers are working on the technical solution.
    Business leaders should fix a policy problem at hand in the support arena.
    No one is going to know or care about 'SIMPLO' after this.
    But the Microsoft/Surface brand will certainly own the aftermath.
    If the percentage of those affected is so 'small' as it has been reported, then why not roll out the red support carpet, or at a minimum do the right thing? After all, aren't you all rolling out a SP5 soon?
    This guy nailed it....
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=e725a996-b838-43c0-9afd-55daf777a5e3)
