2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-13T19:50:40+00:00
    It is recommended to maintain battery life, to have a battery fully discharge, then fully charge before using. Recharging from half empty, shortens battery life. Charging a battery very frequently, but in short amounts, shortens the lifespan even further.
    You need to go back and do more reading on batteries.  Different battery chemistries behave differently.  There is a website called "Battery University" I think that has a lot of good information.  And it is consistent with the manufacturer's literature and research papers that I've read.
    That said, I do think that Microsoft has a tough technical problem. I've already mentioned in an earlier post the fuel gauge IC that has its own programming.  It is sealed up in the battery pack and typically there is no way to reprogram it. If you go to the iFixit website and see their teardown of the SP3, you'll see that the battery pack is glued into place.  Highly unlikely that a repair is practical.  More probable is a full replacement which is what MS is probably gagging on right now.  Their lawyers are trying to get Simplo to foot the bill but that is probably like getting blood out of turnip.  One option they may be considering is credit toward a new SP4.
    Ok, I'll go with your FUD.  But not because the battery is wearing out.
    2016-08-13T20:54:53+00:00
    I just spoke with Surface support on the phone. The agent gave me the option to have a replacement unit for $450 out of my pocket.
    He did verbally confirm that Microsoft knows this issue is affecting a "minority" of the surface pro 3 users, and that the Microsoft engineers believes a software update will fix this issue.
    I asked when is the expected fix coming. He said he doesn't know but usually MS releases the updates on the second Tuesdays of the month.
    2016-08-13T23:33:32+00:00
    I also have the issue.  I use my surface pro 3 connected to a docking station most of the time.
    The use of a docking station seems to be mentioned quite frequently in this topic which has me wondering if that is possibly part of the problem; not the docking station itself but the discrepancy between the power it supplies and what the Surface Pro 3 draws under load. Perhaps that has confused the charging state of the battery, in software, or perhaps resulted in the early demise of the physical batteries.
    I use the docking station with my SP3 most of the time. Shame we can't create a survey in this topic to find the ratio of docking station users with this problem.
    2016-08-13T23:50:56+00:00
    I have simplo battery with about 290mWh.  Majority of time spent on docking station with power - only run off normal cord when traveling.  I've been off the docking station for about last 2-3 weeks and fall seems to be level at about 300mWh but have also tried a bunch of other things too - remove power when shut down etc.  So hard to separate the effets.
