2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-13T17:29:46+00:00
    Do anyone any insight into how to do a rollback to an earlier BIOS/firmware version? Been looking for a solution to rollback to the January 2016 update (19 January 2016) which included both a system firmware and hardware update which appears to be the last version where I wasn't experiencing battery drop (either slowly - or really really quickly (last 8 or so weeks).  Unit is currently crippled for intended use due to battery life <1minute. I'm ready to try nearly anything.
    2016-08-13T18:31:08+00:00
    I've been having issues for a few months now and have tried all the fixes. I ran the same report and my battery life dropped to 10% upon unplugging the Surface and going from one room to the next. I found this article - http://www.infoworld.com/article/3102031/microsoft-windows/microsoft-surface-pro-3s-defective-simplo-batteries-trigger-a-class-action-probe.html.
    A class action lawsuit may be in the works. I called Microsoft and their service center disconnected the call while trying to send a text verification. I didn't feel as if I was going to get anywhere with him anyway.
    2016-08-13T19:47:07+00:00
    Did you also try from within Device Manager to uninstall the device driver and (yes) check "Delete the device driver for this device"? Then restart the Surface. I now have driver 1.2.0.2  dated 2015-11-13 - for what it's worth... with my LGC-LGC battery I still have about 2 hours battery life.
    There is also a Surface Power Cover that electrically (but not mechanically) fits the Surface Pro 3...
    2016-08-13T19:50:25+00:00
    I also have the issue.  I use my surface pro 3 connected to a docking station most of the time.  The only reason I uncovered the problem is because it keeps shutting down while the surface is docked - why the surface pro should require the battery while it's in the docking station is beyond me.  The only way I can have it running continuously is by having it plugged directly into an outlet.  However with that I lose wired Ethernet and a second display.  Hopefully Microsoft makes this right soon because I use this for development and the poor wireless performance and loss of a display does effect my productivity.  I have no problem paying a reasonable price for a battery replacement (100-150) but $500 for a refurbished product is not an option for me.  I could also live with it functioning correctly in the docking station.
