2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-12T18:34:27+00:00
    Now I have to be careful to not unplug the cable as the computer WILL power down and a reboot takes some time which account to unproductivity.  Said that, I have to be near ONE power plug at all times to use the tablet and can not switch to an other wall plug as the computer will reboot.
    The Stylus, which is a huge plus on the tablet, is useless because risking to unplug the computer using the stylus is very high.
    So many with the SIMPLO battery issue claim the computer will not even boot.  When MSFT releases the patch to fix this issue, will I still be able to boot and install and recover the battery to it's fullest potential or do we still have to replace the unit.
    Will have to wait and see with what Microsoft will come up with.
    2016-08-12T20:46:29+00:00
    So as of August 12, 2016 do we still not have an update on the issue? My surface pro 3 with SIMPLO battery reports only a 144 mWh capacity which is about enough battery for half a second. I have issues even keeping my surface on with the cable plugged in. I was very happy about my surface right up until I started having this issue last month. Nothing seems to work. I even did a hard factory reset of it and still nothing. I heard installing the old firmware (Prior to April 2016) and letting the battery run down then recharge many times nurses the capacity back to full. Is this true? Either way I'm not giving another $500 to Microsoft if they don't stand by their hardware. It's unacceptable. I know its out of warranty but we shouldn't expect widespread batteries dying a mere 3 months after the warranty expired. I expected to own this for a few years, I guess I will start looking at other hardware companies from now on.
    2016-08-13T00:15:16+00:00
    Yes. I too am looking at other hardware companies. I had originally planned to upgrade to a Surface Book after 3 years with my Surface Pro 3 but after finding my Surface Pro 3 battery died within 18 months and that Microsoft would not stand by their product I am re-considering my plans,
    The surface book has TWO sealed batteries, one in the base and one in the clipboard. Given Microsoft's appalling treatment of its customers over the Surface Pro 3 battery failure why on earth would I still consider purchasing a product from them which is twice as likely to suffer the same fate?
    2016-08-13T02:07:27+00:00
    I just want to add that I was laughed at and made fun of by Microsoft Tier 1/2 technical support tonight as I explained the issue and stated that I would not do a hard reset when this is a demonstrably serious and publicly acknowledged problem.
