2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-12T17:35:01+00:00
    I, too, have been having this problem. By all accounts, looks like it probably is a software/driver issue since everyone's report shows issues started around the end of March, beginning of April, regardless of how old the device is. My Surface was purchased in October of 2014 and has been working great until about the same time as everyone else, the week May 9th. It was then that the capacity started to drop exponentially.
    Hopefully it is a driver or software issue. If not, hope Microsoft steps up and helps everyone.
    2016-08-12T17:46:26+00:00
    At this point, we've done all the research and speculation we collectively can. Now we need to hang on till MSFT communicates. Microsoft is primarily an engineer's company, which means that they don't do communication well. Is that acceptable? **** no, but that's what we've got.
    They have past history of standing by their customers - i.e. RROD, so I won't be too worried. I'd rather have silence till they figure things out, than patronizing smartarsery such as "you're holding it wrong"; or "you're charging it wrong" in this case lol!
    2016-08-12T17:54:28+00:00
    It isn't easy to have patience when the device I paid £1,700 for can't be used for the business trips and meetings for which I purchased it for.  The devices in an unusable state should have a replacement option offered until they figure it out.
    2016-08-12T17:58:36+00:00
    Could someone please address my post? (approx. 6 posts back)
    Thank-you.
