2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-12T03:13:21+00:00
    I just want to confirm.  We can sign up for a class action suit against Microsoft here?
    If that is the case, everyone in this forum should get in immediately before Microsoft screws us more.
    You can register with the law firm ( Migliaccio & Rathod LLP ) and there's no guarantee it will result in a class action law suit, but considering the overwhelming evidence and pattern of battery drain, I'm sure Microsoft will get sued, even after they've applied a fix, because of the loss of income and damage to business users productivity and reputation when using a Surface Pro 3 as an business tool. Loss of revenue as a result of a manufacturers defect, on such a large scale will inevitably lead to people wanting to be compensated for the loss of immediate and future revenue as a result. A Sales person who loses a multi million dollar contract because their Surface pro dies mid presentation, is going to be pretty pissed and if proven the device resulted in the loss and Microsoft is at fault, that loss of revenue can be reclaimed from Microsoft. A lot of people use the pro 3 as a business tool, because of the Microsoft pitch of it being a laptop and a tablet.
    Personally, I'm not convinced that a software/firmware upgrade will resolve it. I think the bug will be fixed, but by the time the fix is applied, flat batteries that are charging to 144 mWh are irreparably damaged and the fix will remove the cause, but won't undo the damage.
    2016-08-12T14:12:39+00:00
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER xxxxxxxxxxxxxxx
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 144 mWh
    CYCLE COUNT 345
    So I'm screwed?  My device shuts down randomly now docked making it unusable.  I may take back to store and see if they can help me.  With the dock hdmi casting plug and extra chargers I'm out $1500. Support wants $99 just to tell them about the problem so why would I give them another $99?  I feel so wronged.
    2016-08-12T14:22:12+00:00
    Take it back to the store if you can. The MS store replaced mine for free. See my post on page 79 for details.
    Good luck.
    2016-08-12T14:25:34+00:00
    Installed batteries
    NAME X898289
    MANUFACTURER SIMPLO
    CHEMISTRY LION
    CYCLE COUNT 345
    According to Microsoft reply about 2 or 3 weeks ago they said that they believe the cells are not the problem is a software issue.
    I'm not an expert on the matter but what I understand is that they can recover the loss in battery life. They may be working on some kind of battery re-calibration software to recalibrate the battery....who knows.
    Thats what I understand!
