2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-11T15:09:18+00:00
    So now I am almost completely bricked.  I'm down to 144mWh, and the SP3 is seemingly stuck at 16% but NOT charging.  I cannot use the dock which is necessary for my deskwork.  No response from Microsoft means I've contacted the class action lawyers, and am also initiating a warranty claim with Mastercard (check your card conditions as you may be entitled to an extended warranty).  I'm losing productivity, and there's no end in sight.  I had hoped that Microsoft would step up and keep us in the loop.  Unfortunately, not. . . .
    2016-08-11T15:10:53+00:00
    You know folks, this battery issue is getting very old.  The answer seems to be "We are working on it" or It is out of warranty and will cost you $500 +.
    There is a very obvious problem, and Microsoft will not solve it.  If they are forced to replace all of these SP3's it will get their attention.
    My suggestion is we need to start a class action law suit against Microsoft.
    I am tired of Microsoft making me look like a total idiot to my clients!
    One is already in the discovery phase: Migliaccio & Rathod LLP
    2016-08-11T16:29:00+00:00
    What exactly will this resolve?
    2016-08-11T16:56:13+00:00
    I am going to contact AMEX and see what they can do before I have a lot of bricks Microsoft will not fix.
