2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-11T14:20:21+00:00
    I am seeing a lot of references to this happening at about 15 months of ownership which is also when it happened to mine. I wonder if there is any significance to this time period? Or is that just when they started to switch battery suppliers to LG?
    2016-08-11T14:27:13+00:00
    From my limited understanding of legal matters, the class action route is the mechanism by where we as individual users will benefit.  A larger organization could sue on their own behalf and win, but that would not mean Microsoft has to make all SP3 users whole.
    2016-08-11T14:40:36+00:00
    This issue is not only on SIMPLO, is affecting LGC batteries as well. Mine have lost 33% of its total capacity, some have reported more degradation on LGC, I believe as time passes LGC is going to catch up with SIMPLO. Also, is not that before was SIMPLO and later they switch to LGC. I bought my surface exactly on day 1 of release and it came with an LGC battery.
    2016-08-11T14:41:46+00:00
    The value of 2 enables the option to throttle the CPU, to set it to 65% you have to go into the advanced power options (go to Control Panel\All Control Panel Items\Power Options\Edit Plan Settings, then click Change advanced power settings)
