2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
  1. Deleted
    2016-08-11T12:46:33+00:00
    What is the status on this issue?
    My battery is no longer working and worse my SP3 tablet shuts down even when plugged in.
    2016-08-11T12:55:14+00:00
    It seems clear to me that Greg's response was not officially sanctioned and he spoke out of turn and has been reprimanded for his actions.  Probably lost his job over it which is a shame as he deservers to be applauded for speaking out on this issue.
    I suspect the Surface team is actually getting hauled over the coals as the realisation strikes that they have a recall the size of the Xbox 360 with a significant financial penalty.  This will be sat with the legal teams so expect months of drawn out delays without any further communication.
    2016-08-11T13:40:15+00:00
    Hello everyone,
    We are aware of some customers reporting a scenario with their Surface Pro 3 batteries in which the system is reporting lower battery capacity than expected. We’ve isolated this to a limited number of customers experiencing this issue.
    Based on our investigations we can confirm that it is not an issue with the battery cells, and we believe this is something that can be addressed via software.
    We’re working through the details of how we deliver that.
    Thank you all for the details you've shared here,
    Greg
    Thank you, Greg, for the response.  It is much appreciated.  Below is the status of the SIMPLO battery in my Surface Pro 3.  As you can see, there has been quite a sharp drop in battery capacity since March.  Would you be able to tell us when a fix (presumably via a software update?) might be available from Microsoft?
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=904d750c-6a24-4ae6-a604-5d9762b7763e)
