2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-11T01:42:39+00:00
    You know folks, this battery issue is getting very old.  The answer seems to be "We are working on it" or It is out of warranty and will cost you $500 +.
    There is a very obvious problem, and Microsoft will not solve it.  If they are forced to replace all of these SP3's it will get their attention.
    My suggestion is we need to start a class action law suit against Microsoft.
    I am tired of Microsoft making me look like a total idiot to my clients!
    2016-08-11T03:05:19+00:00
    I don't have the stats for the battery but the techs at the Microsoft store ran all the tests today and just gave me the bad news that the battery is dead.  My choices are a refurbished (not gonna happen) or to drop another bundle of cash for another new one that could develop the same problem again.
    My decision is to use the Pro 3 plugged in and wait for Microsoft to make it right.
    2016-08-11T03:11:33+00:00
    I talked with Microsoft Support this morning after receiving and email about proceeding with a replacement for my dead SP3. It is now completely dead after having successfully installed the Anniversary OS update and the 8/1/2016 firmware update. It will not boot at all. Unfortunately the Support person stated that while they understood my frustration, Microsoft has only authorized them to offer the $450.00 replacement. I declined. Microsoft's software trashed the SP3 that was 1 and 1/2 months out of warranty. If they still do not have a solution to the problem then it doesn't make sense to dumb more money into it. I will not be buying another Microsoft hardware product anytime soon!
    2016-08-11T03:43:43+00:00
    anyone with LGC LGC batteries facing the same issues???
