2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-09T09:53:37+00:00
    when you charge the surface pro 3 to full, do you have it switched on? or in sleep mode or shut down? if it's in on mode, do you have the screen turned on continuously?
    2016-08-09T09:57:26+00:00
    I have LGC batteries, and I thin it's affect LGC batteries as well, although the degradation is not as serious as SIMPLO batteries. I also wanna try juanmaq's method to restore the battery but so far am still just trying. any recommendations how to restore it back to battery design capacity?
    2016-08-09T10:52:03+00:00
    After my battery degraded to 30000 mWh in only 2 weeks I always manually shut it down when the battery is getting low. Then I recharge my SP3 without turning it on until I think it is fully charged. Now according to Battery Report
    the full charge capacity has been recovered.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=20f90f3e-bf27-44c7-8f0f-b2ab3a717b9f)
    What is strange though is the current full charge capacity is shown higher than the design capacity.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=c96c650e-d1df-4167-9317-8faf0a67a0c2)
    2016-08-09T12:37:36+00:00
    Certainly would be nice if you shared with us the work that you've been putting in to fixing this in the 2 weeks since you replied.  It seems to me you've since discovered this is a bit more complicated than a simple software update.
