2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-08T14:02:30+00:00
    I have the same problem. ANOTHER defective battery. The last one was replaced under warranty less than a month after I purchased the device in Dec 2014.  Now that one is dead also.  I'm reading $200 now but can't even find where to send it to have it replaced.  They want $99 to actually talk to a support tech to find out.
    Definitely will the LAST Microsoft device I will ever buy.
    S
    2016-07-08T16:12:33+00:00
    That is ridiculous! They should be ashamed. Yes, I will not even purchase a MS mouse in the future. They need to make this right because it's extremely wrong. Unfortunate for me, I only had the 1-year warranty and my battery died 6 months after that. $200 is a little more reasonable than the $450 I've seen on other threads. It's still $200 that I should not have to pay. My 4-year old iPad battery is still fine! I've never had a battery operated product die this quickly. This is either a defect, a racket, or both.
    2016-07-08T16:20:20+00:00
    Just adding my name to the list.  Same, same.   Battery began to die a few months ago according to the battery report.
    This is the SECOND bad battery.  Fortunately, the first one was under warranty, now this one begins to fail
    Only solution offered is $450 USD to return and replace with a "similar" product.   This was an expensive purchase.  I7256GB so top end/top price. Can't tell you how disappointed I am that I got less than two years use out of this Surface Pro 3.  After having 2 batteries fail, clearly there's a battery problem...manufacturing..firmware..I don't know but dammed if I'm going to give Microsoft another $450 to replace a cheaply built, crappy product with another one.   For that matter, I will certainly never buy another one nor recommend one to anyone else.
    S
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1163663876
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 790 mWh
    CYCLE COUNT 139
    2016-07-08T17:01:09+00:00
    Oh, that's fabulous (insert ticked off face!). I go to that link and have to pay $99 to get support on my Surface. I'm certain I'd pay that $99 just for them to tell me to send it to them to purchase a $500 battery. My surface pro 3 is 18 months old! The battery should not have died this soon. This is a racket and will end up in a lawsuit, which I'm looking forward to. In the meantime, I'll never purchase another MS product until I have my battery replaced at no cost. I spent $1,400 on this product and this is unacceptable.
