2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-08T15:32:04+00:00
    They send me a refurb one with new LG cells and SSD,however,I'd have to redesign my sticker。。。。。。
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=a6e3c5c5-90cf-4e74-bc13-b8cf7a75f365)![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=150b5a6d-08ca-45b0-8b96-0adfb271791c)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=df3e5ba5-58e2-4831-a654-924f0ce1f7c2)
    Which country/ city?
    Was your device under warranty?
    Did you buy it from MS store online/ physical MS store or a reseller?
    Where did you get the refurbished unit from? Store or reseller?
    These are some of the questions that come to mind.
    Can you share these information in this group?
    Thanks in advance.
    2016-08-08T15:46:06+00:00
    yes i have tried everything over the last few months  including reinstalling  windows 8 and 10
    microsoft admitted it was battery failure in march but  i wasnt paying  £400 for a replacement  with only a 3 month warranty
    So Microsoft knew about the battery degradation back in March 2016? I wonder how much longer before that they were aware of this issue? It would be very useful to know if anyone else has an earlier date of contact with Microsoft about this issue.
    2016-08-08T15:53:21+00:00
    I just wanted to send you an update concerning my Surface Pro 3. It had been running at 144 mWh at full charge. The other day I upgraded the OS to the latest version on the Insider Fast Track. All went well, but the firmware update (8/1/2016) failed due to battery being at less than 40% charge. I tried again and the second time the firmware updated successfully. During the entire upgrade process the SP3 was connected to the stand alone charger since the docking station charger is too unpredictable. I continued working on the SP3 for 2 hours and then left it running. The next morning when I went to the SP3 it was off and refused to start. The detachable keyboard would not light up. It did not respond to the power button or the power button with the up volume held down. I have tried each day to get the SP3 to work, but it is now completely dead. I know Microsoft believes the problem to be a software issue, but at this point there is no way to boot the SP3. The cord of the standalone charger does light up when attached to the SP3 and when the power button of the SP3 is pushed the light will blink once 30 seconds later. Hopefully Microsoft has a plan for rebooting the effected computers that are now completely dead in order to install the new software.
    2016-08-08T15:57:39+00:00
    At least MacBooks last that long! Tweet him with #BatteryGate & maybe he'll do something (I don't hold out much hope though)
