2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-08T14:41:06+00:00
    i am also LG battery  67% on 63 cycles but my main problem i hav e just now  is im down to 6% not charging on the plugged in power
    it was 90%  plugged in not charging when it stopped working on battery power  5 months ago and i have hardly used it  since
    im expecting it to be bricked shortly  and a software update is no good as it is saying i dont have the 40% charged battery required to install updates
    2016-08-08T15:05:48+00:00
    Andy,
    Have you tried uninstalling and re-installing the surface battery driver in Device manager. Do not erase the driver just uninstall and re-install. I heard that sometimes that clears up the plugged-in not charging issue. You may need to restart the computer after uninstalling the driver.
    2016-08-08T15:17:41+00:00
    yes i have tried everything over the last few months  including reinstalling  windows 8 and 10
    microsoft admitted it was battery failure in march but  i wasnt paying  £400 for a replacement  with only a 3 month warranty
    2016-08-08T15:25:08+00:00
    Here is the twitter account of the GM of the Surface line at Microsoft.  Interesting that he is taking a dig at Apple's hardware while his own customers seethe at the **** we have purchased.
    https://twitter.com/IsForAt/status/761387470197891073?ref\_src=twsrc%5Etfw
