2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-08T02:13:13+00:00
    I just wrote a review and it went through.
    2016-08-08T02:13:53+00:00
    Make sure you all take a minute and go to the Microsoft store to post your review of the product and the support you've received so far on this issue.
    https://www.microsoftstore.com/store/msusa/en\_US/pdp/Surface-Pro-3/productID.300190600
    I just did (8th August 2016).
    So did I.
    Can't see the comments though... So whether they get past the MS moderators will be intetesting.
    I posted mine and it went through, but shortly after, has either been blocked or removed. I suspect many are being removed.
    Isn't that illegal?
    Microsoft can do what they like on their own review page. It might be unethical, but I doubt it's illegal. Would you really trust the reviews on a manufacturers page about their own products?
    If you do, you should visit my "London Bridge for sale" web site.
    2016-08-08T02:42:59+00:00
    This problem has led to a disastrous summer for me.  The Pro 3 cuts out instantly if not connected to a power source.  Since i have been travelling constantly it has been a source of immense frustration.  This is my third Surface but unless this is fixed rapidly it will for sure be my last.
    2016-08-08T02:44:43+00:00
    This morning, my surface began powering down/hibernating randomly even while docked/main power.
    I couldn't get more than a few minutes out of it regardless.
    I was able to get some stability after changing my power settings.
    Go to your advanced power settings, Expand Battery | Critical battery action | Set 'Plugged in' to 'Do Nothing'
    I know this is only going to work for a while, but it has been keeping it from shutting down for now.
    Hope this helps
