2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-02T20:24:59+00:00
    I started to notice the similar problem last week, as I mostly use it plugged into AC power. But the battery seemed to start degrading since April without my realization.
    My SP3 was purchased late Jan 2015. It hasn't been used much, mostly on travel.
    PERIOD FULL CHARGE
    CAPACITY DESIGN CAPACITY
    2015-07-26 - 2015-08-04 42,343 mWh 42,157 mWh
    2015-08-04 - 2015-08-09 42,358 mWh 42,157 mWh
    2015-08-09 - 2015-08-16 42,362 mWh 42,157 mWh
    2015-08-16 - 2015-08-23 42,374 mWh 42,157 mWh
    2015-08-23 - 2015-08-30 42,268 mWh 42,157 mWh
    2015-08-30 - 2015-09-06 42,248 mWh 42,157 mWh
    2015-09-06 - 2015-09-13 42,423 mWh 42,157 mWh
    2015-09-13 - 2015-09-20 42,431 mWh 42,157 mWh
    2015-09-20 - 2015-09-30 42,404 mWh 42,157 mWh
    2015-09-30 - 2015-10-04 42,553 mWh 42,157 mWh
    2015-10-04 - 2015-10-11 42,583 mWh 42,157 mWh
    2015-10-11 - 2015-10-18 42,583 mWh 42,157 mWh
    2015-10-18 - 2015-10-25 42,583 mWh 42,157 mWh
    2015-10-25 - 2015-11-01 41,841 mWh 42,157 mWh
    2015-11-01 - 2015-11-08 41,535 mWh 42,157 mWh
    2015-11-08 - 2015-11-15 41,100 mWh 42,157 mWh
    2015-11-15 - 2015-11-22 40,948 mWh 42,157 mWh
    2015-11-22 - 2015-12-04 41,708 mWh 42,157 mWh
    2015-12-04 - 2015-12-12 40,668 mWh 42,157 mWh
    2015-12-12 - 2015-12-13 40,592 mWh 42,157 mWh
    2015-12-13 - 2015-12-21 41,061 mWh 42,157 mWh
    2015-12-21 - 2015-12-29 41,314 mWh 42,157 mWh
    2015-12-29 - 2016-01-14 40,934 mWh 42,157 mWh
    2016-01-14 - 2016-01-28 40,949 mWh 42,157 mWh
    2016-01-28 - 2016-02-04 40,911 mWh 42,157 mWh
    2016-02-04 - 2016-02-11 40,326 mWh 42,157 mWh
    2016-02-11 - 2016-02-25 42,340 mWh 42,157 mWh
    2016-02-25 - 2016-03-17 42,583 mWh 42,157 mWh
    2016-03-17 - 2016-04-01 42,583 mWh 42,157 mWh
    2016-04-01 - 2016-04-04 42,583 mWh 42,157 mWh
    2016-04-04 - 2016-04-16 42,151 mWh 42,157 mWh
    2016-04-16 - 2016-04-20 41,635 mWh 42,157 mWh
    2016-04-20 - 2016-04-29 42,583 mWh 42,157 mWh
    2016-04-29 - 2016-05-13 40,751 mWh 42,157 mWh
    2016-05-13 - 2016-05-20 30,477 mWh 42,157 mWh
    2016-05-20 - 2016-05-27 28,014 mWh 42,157 mWh
    2016-05-27 - 2016-06-03 21,374 mWh 42,157 mWh
    2016-06-03 - 2016-06-10 18,559 mWh 42,157 mWh
    2016-06-10 - 2016-06-17 18,194 mWh 42,157 mWh
    2016-06-17 - 2016-06-24 13,025 mWh 42,157 mWh
    2016-06-25                       12,312 mWh 42,157 mWh
    2016-06-26                       10,996 mWh 42,157 mWh
    2016-06-27                         7,955 mWh 42,157 mWh
    2016-06-28                         7,752 mWh 42,157 mWh
    2016-06-29                         7,752 mWh 42,157 mWh
    2016-06-30                         7,301 mWh 42,157 mWh
    2016-07-01                         6,992 mWh 42,157 mWh
    2016-07-02T21:03:36+00:00
    Just for a reference: mine was also purchased in January 2015 and also mostly plugged.
    2016-07-05T07:41:53+00:00
    Microsoft sold us a defective product. At the moment I do not want to admit to mistakes. Tells us to pay for their own mistakes almost the equivalent of a new device.
    It is as if we bought a car that burns 10 liters per 100 km and suddenly after a year will burn 1,000 liters. The car and the tablet is not suitable for use.
    The last time I bought something from the company.
    Is it possible to contact Microsoft and the transfer of the problem outside support? I can not believe that Microsoft is not aware of the problem.
    For such actions and deception Microsoft should pay fines and return the money.
    I would like to publicize this case in the online media. Maybe something off the ground.
    I also have a request to other users to contact their portals technological and paid attention to this problem. Without making noise about it will be difficult to enforce any decisions on MS.
    2016-07-05T11:16:18+00:00
    Over the past week, my battery has been recovering. I hit a nadir at 21971mWh a couple weeks ago, and has crept back up to 33850mWh today (and will hopefully continue to rise).
    I've been going through full discharge/charge cycles.
    FWIW I also have a SIMPLO battery and bought my SP3 about 19mo ago.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=119b1623-90d6-457d-b6f4-d34b8d6b1e82)
