2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-05T23:19:58+00:00
    You're bashing stuff that's got nothing to do with the problem at hand. Cheap screen? Really?
    2016-08-05T23:31:30+00:00
    May 2015.  I am out of warranty, but BB is taking it back and refunding 100% in store credit.
    2016-08-06T00:05:15+00:00
    That's very interesting as I bought mine from BB as well around Jan/Feb 2015.
    Did you have to raise **** or how did you get them to take it back?
    Thanks in advance.
    2016-08-06T00:16:24+00:00
    Not at all.  I went in to buy a replacement laptop, just mentioned what I was replacing and they offered.
