2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-05T21:45:03+00:00
    Unfortunately we are having exactly the same issue.
    Surface Pro 3, i7.
    The battery lasts about 30 seconds. Even when charging, the battery can deplete and drain faster than it stays charged when the CPU is being taxed.
    This problem has rendered my $1700 device completely useless.
    We either need a software fix or a replacement for the battery.
    2016-08-05T22:07:28+00:00
    UPDATE - I just went to Best Buy to purchase a new laptop to replace my SP3.  Best Buy is recalling these and is giving me a store credit for what I paid for my SP3.  For those of you who purchased from Best Buy you might want to check it out.
    2016-08-05T22:36:34+00:00
    Is anyone aware of a way to provide more power through the connector, perhaps by wiring it to a larger power supply that can supply more than one amp at five volts and more than 2.58 amps at twelve volts?
    I am wondering if it is the voltage of the battery that is shutting the SP3 down and bricking it or if a more capable supply would allow me to use it as a wired-to-the-wall computer.
    Not looking for opinion on this.  No offense, but I could care less about your guess.
    I am looking for someone who can discuss the battery circuitry and tell me that at as long as the battery is cooked, it won't start no matter how much power is available.  Or, in the alternative, yeah, maybe providing more power would allow it to boot.
    2016-08-05T23:16:07+00:00
    That's interesting. When did you purchase your SP3?
