2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-05T18:41:15+00:00
    Add me please to this growing list of unhappy consumers.
    My SP3 i7 battery life is unbelievable and of course I am out of my warranty.
    Don't know if the Surface is a laptop replacement or MS should advertise it as a new expensive ultra thin desktop ?!......casue I need to have the power adapter plugged in ?! Anyway, I guess I am lucky cause I read about other consumers having issues even the SP3 is connected to the power adapter.
    We've paid lots a money for a product from a well know company .....but here I am with a "Toys R Us" device ..... that is getting broke after 18 months of usage....
    Hope Microsoft is listening to our voices and at least they can keep us updated with where are they with fixing this "SIMPLO" battery nightmare....
    Microsoft ..... is your turn to respond to us, please.......
    2016-08-05T18:56:01+00:00
    So, it's now getting even worse for me. I can have my SP3 fully charged. Then I connect to my dock and begin to work. The battery slowly depletes until my Surface goes to sleep (without warning!). After sleeping for about 30 seconds, it will power back on only to go back to sleep again in a few minutes (again without warning). This morning it disconnected a Skype for Business call that I was on with a client. Not good!
    Disconnecting the dock and using the standard power adapter works (without the benefit of Ethernet, more USB ports etc.
    2016-08-05T18:57:04+00:00
    I have posted my experience with my SP3 on my Face Book page to warn friends and family about this issue. A lot of people are shopping for back to school devices now and you know how things go viral on FB.  I also posted on the Microsoft Face Book page.  Hopefully this will rattle their cage a little.
    2016-08-05T19:40:33+00:00
    Purchased the Surface Pro 3, 19 months ago, and I can only use it when plugged in to power. I tried all the resets, trouble-shooting steps, refresh of Windows 10 but the battery issue has not been corrected.
