2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-05T16:31:29+00:00
    Just taken my SIMPLO affected Surface into PC World for assessment.
    My Pro 3 is basically close to being a brick...strange things started happening over the last few months but when it went downhill it went down fast..so if you are reading this thread for the first time because yours is doing strange things make sure you dive in and make a backup quickly.
    I also got a quote for repair from a different independant repair shop. 370 quid plus VAT.. Expensive because the screen will probably crack during the repair. These things were obviously never meant to be taken apart, so it would be reasonable to expect that the battery should last for the expect useful lifespan of the machine.
    I'm hoping that PC World do the right thing and replace or repair. It's only a few months out of warranty....this machine should have been good for years.
    2016-08-05T18:18:40+00:00
    I'd like to add my voice. Have a SIMPLO battery and it's degraded to useless. 3 months past warranty - right on queue.
    Microsoft's response is outrageous for such an expensive machine. I would characterize it as unethical, if not outright fraud. Microsoft - you fix this or you will lose many very loyal customers  who will be shouting your disgrace.
    2016-08-05T18:36:04+00:00
    It might be a good idea for everyone to contact the law firm that is investigating the possibility of a class action.  I did and all they are doing for now is taking down basic information (when purchased and from whom, purchase price, where I live, and contact information).
    2016-08-05T18:38:13+00:00
    Looks like Microsoft over priced this surface pro 3. Looks like they decide to go cheap on most of the components that way they can re-sell for twice or more what is worth. Now is when everything is starting to explode.
    1. The pen draw jagged lines when drawing diagonal lines slowly. NO FIX. (cheap technology)
    2. The wifi card is garbage. Does not connect at decent speeds. (cheap chipset)
    3. The camera on the back is fixed focus, can not be use for close up pictures. (cheap camera)
    4. It over heats and consumes too much battery.
    5. Screens get cracked just suddenly. (cheap screen)
    6. The surface bends like a banana.
    7. Now this cheap battery that doesn't hold the charge. I have an Ipad 3 that i bought in 2012 when it was released and the battery still strong, and ironically I use that Ipad more than the surface.
    Am I missing another issue? I would never buy a surface again and I don't recommend them.
