2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-05T12:50:40+00:00
    I've been using #BatteryGate.
    Also, I'll leave this just here so do with it what you will...
    Mr Satya Nadella (seems to have a use limit so I'll be more obvious: satyan at microsoft.com)
    Can't seem to find any contact details for Mr Panay (I wonder why!)
    2016-08-05T13:04:29+00:00
    Another update. Surface would not power on this morning at all connected to the charger. Finally got it to boot than it started the boot loop again from powering off right as the desktop would load. Let it set a while came back powered it back on got to the desktop finally. So at this point the thing is useless can barley use it has a desktop and cannot using it as a tablet at all.
    2016-08-05T14:40:40+00:00
    Hi Greg
    If it a software rather than a hardware issue, what happens to those like myself with a Surface Pro 3 that no longer charges or powers up? The battery is stone cold dead and even when plugged into the electrical supply now remains dead - no backlight, nothing. It's impossible to startup despite all the troubleshooting info on the Microsoft Surface website. Microsoft Support are appalling as this issue occurred in very early July a few weeks out of warranty.
    2016-08-05T15:18:04+00:00
    Hi Greg
    Exactly. Software fix depends upon working hardware.
    Add two more surface pro 3s to the list of those that no longer work when docked. They just all of a sudden turned off.
    So now I have surface devices that will only work when plugged directly into power cable (likely soon to be bricked), and costly docks that are also useless paper weights.
    Wonderful!
