2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-05T10:09:36+00:00
    Many of us are now totally bricked.  I have looked for a replacement as I need a computer, I need it now.  The Surface Pro 4 is way ahead of the rest.  I'm very uncomfortable buying Microsoft again.
    Anyone out there have a non-Microsoft, Windows 10, very thin replacement for the Surface Pro 3?
    I just can't wait now that my device is completely bricked.
    Steve
    2016-08-05T11:51:17+00:00
    HP Spectre range looks very good.
    2016-08-05T12:34:31+00:00
    So basically Microsoft are still trying to profit from this & still putting it behind a $99 pay wall? Some devices are basically bricks at this point so no software fix will help those now. Can't believe I have to spell out good customer service to these morons:
    • Devices where battery is so dead device can't boot - allow customer to send in for FREE repair now
    • While the repaired devices could still suffer from this issue at least they would be working & able to apply fix
    • Those with devices still usable just keep us informed & provide some timeline for expected release of fix
    This isn't that difficult is it?  After all some of us have paid nearly $2,000 for these unusable devices.
    Don't bother tweeting Panos Panay, he doesn't use twitter except occasionally to remind us all how passionate he is about the engineering perfection of Surface.  Let's face it, if he used twitter he'd have to face up to what a disaster Surface actually is generation after generation.  To repeat there has never been a problem free Surface Pro device. Ever.
    2016-08-05T12:44:34+00:00
    I have tweeted @panos_panay with #SP3batteryfail for all the good it may do.
