2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-04T22:37:38+00:00
    So does MSFT just have moderators / employees randomly browse these threads? How did Greg[MSFT] notice this thread to come and leave his comment when he did? Is there some way to ping one of those moderators directly to suggest they get on here and give some sort of update? Surprising how many tech publications have put out articles about it, only being able to cite a single response from a single employee at MSFT.
    2016-08-05T00:10:52+00:00
    Do we all tweet to Panos Panay to have an effect?
    With no battery detected I don't feel like using the device any more.
    2016-08-05T01:00:40+00:00
    Couldn't hurt - @panos_panay #FixMyBatteryOrBust, #NoBatteryNoPeace, #ContainTheDrain, #LeggoMyLi-Ion, #IWouldHashtagMoreButMyBatteryIsRunningLo..!
    2016-08-05T09:47:50+00:00
    I have the same problem simplo battery and a surface pro 3 which is about 20 months old. I use win 8.1 as I use my pro as a tablet almost exclusively. I merely wanted to register my problem to add to a growing list. I somehow feel its not a software related issue as I had updates turned off for over 12 months and just turned them on 5 days ago. Its worth noting majority of updates 'failed'. I couldn't be bothered to go through the hassle of fixing this. MS must think there customers are immortal.
