2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-04T14:50:39+00:00
    Received this message from Microsoft after calling into Customer support. I explained that I would not pay the $99 for the call since this was a known issue. After confirming that my SP3 had a SIMPLO battery at full charge with 144mWh and I had already done all the suggested diagnostics, the support person offered 2 options, 1) paying $450 for an exchange which would be the fastest option or 2) waiting for Microsoft to come up with a solution, which is a top priority for their surface team.
    160731
    Good day!
    Thank you for the response.
    I apologize if you still encounter the same issue. I understand where you are coming from. No worries, this has been reported so rest assured that our Engineering Team will be working on this closely. We will let you know via email on whatever progress we may have for this issue.
    Once again, thank you for reporting this to us and I really do apologize for any inconvenience this may have caused you.
    2016-08-04T14:57:44+00:00
    I have the SIMPLO battery issue with my Surface Pro 3 i5 and was able to upgrade to the Windows Anniversary Upgrade.
    The only change that I have noticed is that powercfg /batteryreport no longer produces a detailed history for any of usage, battery capacity, or battery life estimate which is an exceptionally disappointing change as it just hides the what was a very clear picture of degradation starting in April.  At least I had saved a previous version (shown below).
    I am also exceptionally frustrated that I don't appear to be able to even log this issue without paying $99 even though my warranty only expired in mid June and the problem obviously started well before that.
    Battery capacity history [July 28 report]
    Charge capacity history of the system's batteries
    2015-12-06 - 2015-12-15 42,074 mWh 42,157 mWh
    2016-03-20 - 2016-03-27 42,560 mWh 42,157 mWh
    2016-03-27 - 2016-04-03 40,748 mWh 42,157 mWh
    2016-04-03 - 2016-04-11 37,577 mWh 42,157 mWh
    2016-04-11 - 2016-04-17 33,700 mWh 42,157 mWh
    2016-04-17 - 2016-04-24 30,962 mWh 42,157 mWh
    2016-04-24 - 2016-05-01 32,270 mWh 42,157 mWh
    2016-05-01 - 2016-05-08 29,451 mWh 42,157 mWh
    2016-05-08 - 2016-05-16 26,940 mWh 42,157 mWh
    2016-05-16 - 2016-05-26 23,297 mWh 42,157 mWh
    2016-05-26 - 2016-06-03 19,942 mWh 42,157 mWh
    2016-06-03 - 2016-06-10 19,900 mWh 42,157 mWh
    2016-06-10 - 2016-06-17 18,218 mWh 42,157 mWh
    2016-06-17 - 2016-06-24 17,558 mWh 42,157 mWh
    2016-06-24 - 2016-07-01 16,997 mWh 42,157 mWh
    2016-07-01 - 2016-07-08 16,070 mWh 42,157 mWh
    2016-07-08 - 2016-07-15 13,099 mWh 42,157 mWh
    2016-07-16 10,579 mWh 42,157 mWh
    2016-07-17 10,579 mWh 42,157 mWh
    2016-07-18 10,579 mWh 42,157 mWh
    2016-07-19 10,143 mWh 42,157 mWh
    2016-07-20 8,519 mWh 42,157 mWh
    2016-07-21 8,322 mWh 42,157 mWh
    2016-07-22 8,322 mWh 42,157 mWh
    2016-07-23 8,322 mWh 42,157 mWh
    2016-07-24 8,322 mWh 42,157 mWh
    2016-07-25 8,230 mWh 42,157 mWh
    2016-07-26 7,942 mWh 42,157 mWh
    2016-07-27 6,853 mWh 42,157 mWh
    Battery capacity history [full Aug 4 report!]
    2016-08-03 5,138 mWh 42,157 mWh
    2016-08-04T15:53:03+00:00
    are these docked most of the time?
    Yes they are dock 90% of the time.
    2016-08-04T18:01:45+00:00
    Hey Greg,
    Like many other people here I am having similar issues. This is ridiculous as my SP3 is now pretty much useless and it's not even two years old. Honestly at this point I would not be able to recommend any Microsoft hardware products to friends or family. I regret making the decision to buy this device instead of the MacBook Pro. At this point I want a useable device and I think Microsoft should just bite the bullet and replace the batteries for users that are affected by this issue.
    I am not Happy. And I doubt I will ever buy another surface again unless Microsoft fixes this issue promptly and actually takes users complaints seriously.
