2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-04T11:58:14+00:00
    Hi Barb,
    You can add me to the growing list of SP3 owners with a dead Simplo battery.  As with others, it started failed right after the warranty was up and progressed rapidly to turning off immediately when unplugged.  It's an i7.  Here's the part of the battery report showing when the capacity dropped.
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1163598340
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 144 mWh
    CYCLE COUNT 165
    2016-03-27 - 2016-04-03 33,446 mWh 42,157 mWh
    2016-04-03 - 2016-04-10 28,553 mWh 42,157 mWh
    2016-04-10 - 2016-04-17 23,690 mWh 42,157 mWh
    2016-04-17 - 2016-04-24 22,894 mWh 42,157 mWh
    2016-04-24 - 2016-05-01 18,903 mWh 42,157 mWh
    2016-05-01 - 2016-05-08 16,380 mWh 42,157 mWh
    2016-05-08 - 2016-05-15 8,059 mWh 42,157 mWh
    2016-05-15 - 2016-05-22 6,061 mWh 42,157 mWh
    2016-05-22 - 2016-05-29 2,878 mWh 42,157 mWh
    2016-05-29 - 2016-06-05 1,544 mWh 42,157 mWh
    2016-06-05 - 2016-06-12 263 mWh 42,157 mWh
    2016-06-12 - 2016-06-19 143 mWh 42,154 mWh
    2016-06-19 - 2016-06-26 144 mWh 42,157 mWh
    2016-08-04T12:13:00+00:00
    Hi, I strapped an icepack to the back of mine - but still could not get more than a few minutes running.
    After the stage where it reboots when running the GPU/FAN it has another stage where it won't get past POST.
    I stuffed mine in the freezer at that point for a few minutes and luckily got it to start up one last time to get the local data off to USB stick - be careful not to run chrome or and app that taxes the CPU.
    I also found I had to unplug the keyboard and Mouse to save their power drain, had the screen on 0% brightness.
    I tried using an external monitor with the tablet monitor off but that didn't help
    2016-08-04T12:36:27+00:00
    We have 3 Surface 3 Pro here all with Simplo Batteries all bought around the same time. I have checked every one and mine is the only one having the issue. the other two show no signs off it their battery reports show their batteries are preforming a little above spec.
    2016-08-04T13:13:46+00:00
    are these docked most of the time?
