2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-03T23:25:24+00:00
    Well i have to say things have gotten worse. I'm writing this from my phone because my SP3 can't even get past boot up without dying even when connected. I disconnected all extraneous devices, disabled the wifi, and lowered the screen brightness and it's still not enough. When it does manage to make it to the desktop screen the battery reads "0% available, plugged in, not charging." I can't connect to the internet without it shutting down let alone go through the file explorer as the slightest bit of activity is enough to make it go out. No more battery reports! The last battery report I made showed a capacity of 144 mWh. I assume it's gone down. Again. If this isn't rock bottom, it's nearly there.
    Word of advice to everyone else: back up everything while you still can and prepare a contingency plan. If you thought things couldn't get worse, well i have bad news for you. Better prepare now before you regret putting your faith into waiting for Microsoft. I tried to be patient and all it's gotten me is a glorified brick that sometimes lights up when connected to a power outlet.
    2016-08-03T23:27:14+00:00
    I know that many of the people (maybe 98%?) reporting the issue have a specific battery name, X898289. I got my SP3 in November of 2015 and it has a different name. Maybe it's a batch thing? Mine's been okay so far, too... knock on wood.
    2016-08-04T00:41:55+00:00
    My battery output shows 100% charged with 1 hour of battery life remaining. But after the device is unplugged in minutes the charge quickly  goes from 100% to 60% with 30 minutes of battery life remaining and within a few more minutes it goes to 40% of battery life with 10 minutes of battery life remaining. The puzzling thing is the device says the battery is 100% charged but at 100% only 1 hour of battery life registers then the battery actually dies in minutes.
    What a piece of junk.
    Run battery report. 100% of 1000 mWhr means nothing
    2016-08-04T00:44:21+00:00
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=915ea048-ef70-4c3c-861a-85230e97cf32)
    Did you try an external cooling fan to keep the internal fan from running high?
    I have to put a fan at the back to keep the thing from frying. Even 60% CPU usage will throw the temperature to 90s degree C, then the battery starts to drain even when the device is plugged in.
    Yes I spent nearly US$2000 on this model, but any problem that can be solved by money is not a real problem. In this case I would just get a proper laptop and get rid this piece (will put it on eBay soon).
    However, Microsoft is changing a problem that can be solved by money into one that cannot (or at least a more expensive one).
