2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-03T18:08:02+00:00
    thanks
    I tried all the steps  in march and then was told it was a dead battery by microsoft and to pay them £400 for a replacement with a 3 month warranty
    just as well i never took them up on it as they would probably have sent me a simplo one
    2016-08-03T18:49:33+00:00
    Greg,
    I have been reading many different sites and threads with options to try for battery issues but nothing has resolved the problem so far. Reading through some of these posts I have not found the exact same problem I am experiencing but close to it. I have an SP3, i7 running Windows 10. About 2 weeks after the warranty expired on my device I noticed it does not show a battery anymore. It won't turn on unless plugged in but will run for about 5 minutes or so if I unplug it. Over the last 3 months it has shown the batter less than 10 times and below is a battery report I just pulled.
    I've done factory resets 4 times back to 8.1 and nothing has fixed the issue. I've tried removing the device/driver in device manager and again no luck. It would be one thing if this was the type of device end users could just replace the battery on, even if we had to pay for said battery, but that is not the case with this. We all have paid very good money for these devices and the amount of issues that have come with them are disturbing. I personally doubt that a software fix is going to take care of this problem, and knowing MS they will want to charge us for BatteryasaService and charge us monthly to pad their bottom line.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=f605ca04-db94-45da-8b24-c37990201211)
    2016-08-03T18:54:13+00:00
    Add me to the list of disgruntled SP3 owners-- barely 1.5 years old and experiencing the same battery degradation as the rest of the folks.  Wondering how Microsoft can honestly say that only an "isolated few" are impacted?  I am by NO means a tech expert-- in fact, I had to search on how to run that battery report -- and what disturbs me is that my battery was actually experiencing issues back in early May (unbeknownst to me b/c I primarily use docking station)! The second I un-docked the SP3...battery drained to 80%.
    I can understand that a battery will naturally degrade over time; however this situation is completely unacceptable.  Further, the means by which Microsoft is handling the situation is completely unacceptable-- where's the communication?  Simply posting that they "believe" this is a software fix while also not providing a timeline is absolutely ridiculous.  A corporation of this magnitude-- guarantee they have a full time staff monitoring forums and could craft a better response than what they've provided.  I'm sure it has to do with legal...
    Needless to say, if they do not remedy the situation or provide information soon... they'll lose another loyal customer.
    2016-08-03T19:11:03+00:00
    did you go exploring in Windows.old to see if you could find your old report?
    >>The battery report (from "powercfg /batteryreport") has wiped out the historic information about battery capacity degredation. Other historic information is largely wiped out as well, although some basic information such as cycle count remains.
