2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-03T10:46:08+00:00
    Bought new power cable (waiting for old faulty one to be replaced). Upgraded to anniversary edition whilst plugged in. Battery finally showing 100% charge but went flat within 15 mins of disconnecting from the mains. Am now charging from flat with the new OS installed to see if that makes any difference. I am not expecting much though.
    Regardless of whether it helps I find it absolutely disgusting that someone from microsoft hasn't bothered to advise whether the update will solve the issue or advised when and how it will be solved.
    I will never purchase microsoft hardware again based on this experience.
    2016-08-03T11:15:56+00:00
    I can also confirm that after i upgraded i had a 01/08/2016 firmware upgrade that did a full bios update, so i am watching the battery report now :)
    As I understand it this is not a Windows 10 issue, some have reported it with Windows 8, so the OS isn't going to fix this unfortunately.  The firmware release is not a fix for this as confirmed by the release notes:
    https://www.microsoft.com/surface/en-us/support/install-update-activate/pro-3-update-history?os=windows-10&=undefined
    Remember that this firmware will only be offered if you have the Windows 10 Anniversary Update installed.
    I would also advise caution in testing each new firmware or OS release as running the battery down degrades it even faster so please wait until we know a fix has been released.  This issue has gained quite a bit of coverage so expect those same sites to post updates once it has been addressed.
    I hope this can be fixed remotely, via firmware, as I take very good care of my Surface Pro 3 and do not want a refurbished one to replace it.
    2016-08-03T12:39:11+00:00
    I can't use a portable computer that I paid over $1500 for without it being tethered to power.  Come on Microsoft.  I can't reliably use your product.  It might as well be an anchor at this point.
    I am trying to be patient for this software fix.
    Panos Panay
    "98% of people using the Surface Pro 3 would recommend the device to their friends."
    "Surface Pro 3 is a product people know and love."
    How about now?
    Sorry, my rant is done.  :)
    2016-08-03T12:43:38+00:00
    Panos Panay's passion for his products dies the moment he leaves the stage to work on the next generation.  That man should feel ashamed of the Surface product line as none have been problem free. Every. Single. Launch. Imagine if Dell or HP had an issue with every single device they had ever launched?
    Shocking but unfortunately to be expected after 4 generations of consistent failures.
