2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-03T10:06:37+00:00
    Antony/Everyone
    has anyone with the SIMPLO battery issue been able to upgrade to the Windows
    Anniversary Upgrade successfully using Windows Update? (Go to settings, Updates
    and manually check for updates). There is NO fix there for the issue, but I'd
    like to know if the battery degradation is
    1. preventing the 1607 upgrade from being offered
    2. anything else
    >>How could we possibly apply an upgrade when a charged battery is required?
    2016-08-03T10:17:35+00:00
    someone from MS please throw us an update on this issue, looks like this is major!
    even if you have problems sorting this JUST LET US KNOW
    SOMETHING
    ANYTHING ......BUT SILENCE!
    go to the first page of this thread and read the Most Helpful Reply at the top.
    2016-08-03T10:29:31+00:00
    I have the SIMPLO battery and while mine has not degraded to the point that it can't run on battery I am a Windows Insider registered on the Fast Ring so have been installing preview builds without issues.  The battery "thinks" it is charged above the threshold (40% is it?) as it shows 95% so that shouldn't prevent updates being offered or installed (you may have to use direct power instead of the dock since the dock doesn't appear to provide enough power to remain running for batteries in the worse state).
    Remember the Anniversary Update is being rolled out slowly but Dona Sarkar has provided details on how to "force" the update to show.
    2016-08-03T10:31:12+00:00
    I downloaded the ISO and upgraded.
    My battery was showing 95% max before and 100% max now but still not fixed.
    Also my battery history report is now blank.
    I can also confirm that after i upgraded i had a 01/08/2016 firmware upgrade that did a full bios update, so i am watching the battery report now :)
