2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-03T03:28:31+00:00
    HelloKridsada Thanabulpong,
    Thank you for reaching out to the Surface community. Sorry to hear you are having issues with your battery. If you do in fact have a hardware issue it would be a Warranty/Service related issue that you would have to contact Assisted Support to resolve if you do not have a Microsoft Store in your country. However, to try to determine what is going on with your Surface's battery please follow the troubleshooting steps in this link.
    Please reply with what steps you've tried and what the results were.
    Best Regards
    If you're going to bother to reply, please don't patronize us with the standard response to the useless links that just waste our time and resolve nothing and to suggest a warranty fix that out of warranty devices would require payment for, when the issue is a defect that should require a bugfix or recall, not a warranty.
    What people want to know is: -
    1. Is this something Microsoft can fix with a firmware or software upgrade?
    2. How could we possibly apply an upgrade when a charged battery is required?
    3. Are Microsoft going to continue to play dumb on this issue, or are they in the process of coding a fix?
    4. Will the batteries ever recover?
    5. Is Microsoft simply going to weigh the cost of a fix, against the cost of the bad reputation this will forever plague the surface brand with and against the cost of an inevitable class action lawsuit?
    6. Should we wait for Microsoft to actually do something, or should we all just register our surface pros with the lawyers that are preparing litigation, like the one below, mentioned on this thread, several times?
    http://www.classlawdc.com/2016/07/26/migliaccio-rathod-llp-investigates-microsoft-surface-pro-3-battery-failures/
    Unless you intend to actually answer a legitimate question instead of blowing smoke up our collective a$$e$, please refrain from further patronizing some very pissed off customers!!!
    2016-08-03T05:46:40+00:00
    And just an FYI: After installing these two updates (and I'm not sure which one did it) but I can no longer see my past battery history when I run the powercfg /batteryreport; so backup your reports if you want them for reference.
    I noticed this happening too after updating. Something to keep in mind in case people want to preserve some evidence of this rapid degradation.
    As for the other posters noting that the surface pro 3 is using more power than the charger can supply, I've had a hunch that was happening too. It seems worse with the dock so I've been using the regular power cord. Unfortunate to see that I can't even use my dock anymore since it literally shuts down after logging in while docked.
    2016-08-03T06:14:12+00:00
    I couldn't agree more with your sentiments. It's meeting frustrating to get stuck a response which clearly shows ignorance and a lack of caring to even have a small idea or understanding of what it's being discussed and what the actual issue it's... One that obviously has no chance to correct very much not limited issue. It makes me wonder if Microsoft has any effective level of internal communication for a support agent to respond in sick an sounds way. How can anyone with MS support not be aware of this issue at this point!
    2016-08-03T06:20:25+00:00
    someone from MS please throw us an update on this issue, looks like this is major!
    even if you have problems sorting this JUST LET US KNOW
    SOMETHING
    ANYTHING ......BUT SILENCE!
