2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-02T23:28:09+00:00
    It's interesting your battery report shows 32k mWh capacity yet the device turns off immediately upon unplugging. Makes wonder if the "recovery" reported by other users were for real or just the system reporting a fake number.
    I can confirm that the "plugged in not charging" problem, which is not new, is related to the battery degradation.
    So yesterday after the firmware update, I used the battery to 86% (from 16,621 mWh down to 14,303 mWh), then plugged in to charge it. Encountered the classic "95%, plugged in not charging" problem, where the battery capacity stuck at 15,793 mWh.
    Upon rebooting, the system reports 15,793 mWh as 100%.
    I am guessing that Microsoft faked a fix for the "plugged in not charging" problem by changing the algorithm so that at whatever level the battery refuses to take any more charge, call it 100% charged. The "software issue" that Greg mentioned could be because he knows about that. (Sorry Greg, if Microsoft doesn't want to communicate with the community effectively, all we can do is guessing the cause).
    10:15:01 Active Battery 100 % 16,621 mWh
    10:20:49 Active AC 86 % 14,303 mWh
    10:50:19 Active Battery 95 % 15,793 mWh
    10:50:27 Active AC 95 % 15,793 mWh
    10:58:13 Active Battery 95 % 15,793 mWh
    10:59:21 Suspended 95 % 15,793 mWh
    11:05:20 Active AC 100 % 15,793 mWh
    I also noticed that when I manipulate some 3D CAD models, the battery will drain even the computer is plugged in. Seems the charger cannot keep up with the demand from the CPU and GPU.
    2016-08-03T00:37:32+00:00
    Yes at last, someone that see this problem as I do. The surface pro 3 uses more power than the charger can supply so it becomes a brick.
    Cant use it however it is pluged in to the mains.
    2016-08-03T01:53:23+00:00
    Microsoft fixing the problem or not, this will be my last MS branded PC and my last tablet whoever the vendor is. I thought this would be a capable device judging from the specs, but you never know that such ridiculous problems can happen.
    What's worse, I purchased the surface for it's mobility because I travel overseas quite often to provide support to our clients - only to find that the device cannot see WiFi channels beyond 11 - so it is basically limited to use within the US. I had to plug-in a USB wifi dongle to the only usb port the device has to use the internet while overseas. Within 5 days my battery will die and I will need an external battery pack as well. This is much more hassle than using a proper laptop.
    2016-08-03T02:08:31+00:00
    I'm in the same boat. Shuts off the second I remove power. In the docking station it will not keep up with the power demand. I have to keep the screen brightness on 0% or else it will randomly shut off when the power demand gets to be more than the docking station is capable of.
