2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-02T13:08:56+00:00
    Frank - the Syracuse store was the one I dealt with back in April that was completely unwilling to go out of their way for me. You might try making the drive up there, and perhaps they will do something now that this issue is known to be widespread, but I think your best bet will be to hold tight if you can.
    2016-08-02T13:19:04+00:00
    To save some people a little time in reading the 40 previous pages, I think we can sum up the thread thus far as :
    "More Bricks, No Fix"
    I know this has been said before but let's keep this in perspective.  I have no doubt that Microsoft will fix this, either through software or via an extended warranty replacement (similar to what they did for the Xbox 360), so it's a matter of "when" not "if".
    The frustration I have isn't with if this will be fixed it is the lack of communication which I find disrespectful and unforgivable considering these devices cost upwards of £1,500 so we deserve regular updates.  I also feel they should be doing an open email to all owners, theses devices are registered after all (same way they contacted us about the power cable recall), informing people that there is an issue and that they are working on it.
    The fact that telephone support are still suggesting customers pay to replace the battery is disgusting.
    2016-08-02T13:27:20+00:00
    always plugged ever since I realized this problem. No sign of recovery, steady decline by 300mWh per day.
    2016-08-02T13:42:40+00:00
    Hmm! I wasn't contacted about the faulty power cable. Only just heatd about it when I read your post.
    So now it seems that microsoft's flagship product, which is only 18 months old since I bought it, is incapable of running on battery power and dangerous to use when plugged in.
    What exactly in that description would even vaguely make this pile of junk 'fit for purpose'?
