2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-06-24T11:14:00+00:00
    Thank you - that is very suggestive of a battery manufacturing problem.
    I guess we need about 1000 owners to complain before anything gets done
    2016-06-24T13:21:20+00:00
    Teperature processor exceeds 80 degrees and the same tablet in the right part is so hot that it is difficult to maintain. This is a felerny product! In another thread you can find people with damaged battery.
    http://answers.microsoft.com/en-us/surface/forum/surfpro3-surfhardware/surface-pro-3-2-hour-battery-life/ad93eb3a-3dc4-40f0-9ee6-afa4f090886f?page=2
    2016-06-24T14:02:17+00:00
    My first SP3 and my replacement (current device | i5 8GB) both experience(d) high core temperatures (while browsing facebook, watching videos on youtube, etc.)
    Did not damage my battery (being used for a year)
    However, battery life goes down to about 4 hours on full charge while watching videos (on Chrome or IE; Windows 10)
    Windows 8.1 seemed to get me much more battery life though. I could read a pdf(1355 pg, with images) at 25% brightness on airplane mode for 9.5 hours on full charge, Windows 10 gives me much less
    Will post updates if battery degrades rapidly
    2016-06-26T17:51:27+00:00
    My Surface Pro 3 has no battery life. It works fine on the docking station and shows 100% charge, also when charged directly by the power cord and once off the power it dies immediately. The full charge capacity is a paltry 900mwh compared to the deisgn  full charge capacity of 42K ( we ran a battery report) Has any one else experienced this?
    It started losing power about 1 month ago.
    The battery manufacturer is
    X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1161304580
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
