2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-06-22T16:39:49+00:00
    2016-06-22T18:21:27+00:00
    There is no solution. MS made a great machine on many levels but sacrificed good engineering in terms of power. And have been pretty disappointing with their lack of effort to acknowledge or assist). Once you have battery problems, the only way to continue to use the Surface Pro reasonably is to disable the battery driver. The machine must always be plugged in to power (and the docking station power supply does not serve any more) from then on (and ChargeTech makes a very good portable power source for when you can be no where near a power source). Not great but the machine works flawlessly and it really is a superior laptop/tablet when it functions.
    2016-06-23T04:32:25+00:00
    This is the result from my surface (got it replaced a year ago (May 29, 2015))
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=c83f8b22-3454-4cf7-8565-4f7ea63694ba)
    Manufacturer is LGC (LG Chem (?))
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=50ba571c-a873-4932-96e8-acf9e20af1bf)
    I reinstalled Windows 10 a few months ago so it starts from April, but it actually starts from a year ago
    Maybe its batteries from SIMPLO
    But of course Microsoft should be giving a replacement battery without charging so much?
    Will keep an eye on the battery levels and post updates if it suddenly goes down
