2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-03-17T01:18:04+00:00
    I've been having serious battery drain issue.  As soon as I unplug the Surface I go from 100% battery life to 80ish% in a matter of seconds.  I'm only getting about 30 minutes of battery life from a full charge.
    I've turned it off and let it charge to ensure it was 100%.  Same issue.
    I've gone thru and turned every background program to OFF and still same problem.
    Just today I restored it back to factory.  Same issue.
    I'm really at a loss.
    2016-03-17T11:04:39+00:00
    If you've been through everything at
    https://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/surface-wont-turn-on-battery-wont-charge?os=windows-10
    then you need to contact support
    https://www.microsoft.com/surface/en-us/support/contact-us
    Barb
    Windows Experience MVP
    2016-04-10T23:51:16+00:00
    I don't know what's up, but the battery life of the surface is horrendous, and it's getting quite annoying. I am simply browsing on the web with one tab, and the battery depletes much faster than it should, with nothing running in the background. I have also installed all updates. Is there any way I can have better battery life and be able to use my surface without it heating up?
    2016-04-11T17:28:51+00:00
    YashKumar23,
    Thanks for your query. Please visit this page for information and steps related to Surface battery and how to make it last.
