2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-10-12T14:15:18+00:00
    thanks, I've emailed them with your results from this test.
    >>Before operation: (You can see that the cycle count has a 7 times' jumping again. Yesterday it was 731)
    2016-10-12T13:18:19+00:00
    2016-10-11T17:53:47+00:00
    I hate to say this, but if you completely reimaged, applied the firmware update, and did a couple of complete discharge/recharge cycles, and still have the issue, I wouldn't hold my breath waiting for a fix-- you'll have to pursue the exchange process. I don't like having to suggest this, but I know of no other options. MS thinks that the Simplo issues are resolved AFAIK. You could open an IT Support case (which costs as much as the exchange and gets refunded if you have a reproducible bug) - but I think you'd end up in the same place you are now.
    2016-10-11T17:31:17+00:00
    I have performed the recovery process twice; however, after the Windows updates and firmware are applied, the issue continues.  The battery issue causes the SP3 to die without shutting down correctly; thus, the two issues are mutually inclusive.
