I have a new surface pro 3 and I purchased two docking stations. 1 for the office and one for home. Neither docking stations allows the pro3 to detect a monitor that is plugged into it. I can plug the monitor directly into the pro3 and it detects if fine both at home and at the office. I can tell you that its a serious interruption professionally, and personally and does not bode well for MS's desires to serve the business community. What I need is a solution.
hey guys
I had exact same issue and I did this and the issue magically solved!!
a two button restart:
- Power off the Surface Pro
- Hold Volume Up and the Power button for 10 seconds
- Release buttons
- Wait 5-10 seconds
- Power on the Surface
