Surface Pro 3 dock not detecting external monitor
2014-08-13T15:12:33+00:00
I have a new surface pro 3 and I purchased two docking stations. 1 for the office and one for home. Neither docking stations allows the pro3 to detect a monitor that is plugged into it.   I can plug the monitor directly into the pro3 and it detects if fine both at home and at the office.   I can tell you that its a serious interruption professionally, and personally and does not bode well for MS's desires to serve the business community.   What I need is a solution.
2015-10-25T14:03:15+00:00
hey guys
I had exact same issue and I did this and the issue magically solved!!
a two button restart:
  • Power off the Surface Pro
  • Hold Volume Up and the Power button for 10 seconds
  • Release buttons
  • Wait 5-10 seconds
  • Power on the Surface
2014-08-13T23:38:43+00:00
Hi will-eman,
Thank you for visiting the Microsoft Community! Sorry to know that your Docking Stations are not detecting your external displays. I can certainly understand why this is an inconvenience, especially when, as you mention, it is used in a business environment and for professional purposes. I’d like to help and hopefully provide the best possible solution!
Please try the following:
  • With the Surface and external display connected to the Docking Station, unplug the Docking Station from the power outlet, leave it unplugged for 30 seconds to a minute, then plug it back and see if the displays are recognized.
  • Please make sure all and latest Windows updates are installed. If so, verify all updates were taken while the Docking Station was connected to the Surface.
  • When you connect the external monitor, do you have any other devices connected to the Docking Station as well? And if so, have you tried removing all devices and connecting the external monitor only?
  • Have you tried connecting other external displays to the docking Station? Are ALL displays or devices not recognized?
  • Have you tried the what Ed Bott - MVP suggests?
 Additionally, please read the following support article:
We hope this information works! Please keep us posted!
We are always here to help!
Best Wishes,
191 additional answers
    2015-12-10T13:47:06+00:00
    Ihave a similar issue i Surface Pro 3.  I use the docking station  I have the surface on the left a USB/VGA in the center as my primary monitor and a display port to HDMI on the right.  I have the exact setup in both my home and at work and have been using it  for about 10 months now.   Same issue on two sets of equipment.
    All of the sudden the dislpay does not recognize from the docking station in either set up.  If i connect to the displayport on the surface the 3rd monitor works but kind of defeats the purpose of a docking station.
    Reboot does not fix it.  I did not try the "two button" restart"  but who wants to do that every time the dock anyway.
    This seems to me it is a WIndows Driver issue something must have changed in on of the updates.
    Any recommendations?
    2015-12-10T13:21:39+00:00
    Split from this thread.
    I have a similar issue i Surface Pro 3.  I use the docking station  I have the surface on the left a USB/VGA in the center as my primary monitor and a display port to HDMI on the right.  I have the exact setup in both my home and at work and have been using it  for about 10 months now.
    All of the sudden the dislpay doe not recognize from the docking station in either set up.  If i connect to the displayport on the surface the 3rd monitor works but kind of defeats the purpose of a docking station.
    2015-11-21T09:31:09+00:00
    I have tried every one of these "helpful".. f*****g suggestions.. nothing works
    Where do we get a person who can fix the damn problem
    At Microsoft cost not mine..
    I set up my office around this ****... !!!!
